Someone may not be very familiar with BIOS, and we will show you how to enable XMP with Asus Z77 motherboard here
Before enable XMP, please update with latest version of Motherboard BIOS and clear the CMOS.
OR, you can manually adjust the BIOS as the memory Specification:
Select the DRAM frequency:
Adjust the Timing
Adjust the DRAM voltage
After you adjust/enable XMP profile, make sure that you save the changes & exit.
Also, you can check the DRAM frequency/Timing by CPU-Z
Adjust the Timing
