Custom-Build
  • Custom-Build
    My Rig:
    Code:
    Computer Type: PC/Desktop
    System Manufacturer/Model Number: Custom-Build
    OS: Windows-8.1-RTM-Pro-WMC-x64
    CPU: Intel Core i7 3770k @4700MHz
    Motherboard: Asus P8Z77-V
    Memory: G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX (10-11-11-28-2T)
    Graphics Card: 2x Gigabyte GTX780-Ti-GHz-Edition-3GB in 2-Way-SLI (Power-Target: 106% | Core-Voltage: 1.187V | GPU-Clock: 1241.5MHz | Memory-Clock: 7290MHz)
    Sound Card: OnBoard Realtek ALC892 8-Channel High Definition Audio
    Monitor(s) Displays: Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    Screen Resolution: 1920x1080
    Keyboard: Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Mouse: Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection | Zalman FPSGun Mouse | Logitech G9
    Mouse-Pad: Roccat Siru
    PSU: Corsair AX1200i
    Case: Thermaltake Level-10 GT LCS
    Cooling: EK H3O HFX 240mm Liquid Cooling Kit + IC Diamond 7 Carat, CPU Thermal Paste-Grease-Compound
    Hard Drives: - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr - Samsung 840 EVO SATA3 500GB - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache - Seagate FreeAgent USB 2.0 1TB - Seagate FreeAgent USB 2.0 2TB - Seagate FreeAgent GoFlex USB 3.0 2TB
    Optical Drive: LG HL-DT-ST BD-RE BH12LS38
    Internet Speed: ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    Browser: Google Chrome
    Antivirus: Windows Defender
    Other Info: - Logitech Extreme 3D Pro Joystick - Plantronics GameCom Commander 7.1 Headset - Logitech X-210 Speakers
    Looks like that I had a few little hick-up's in the background with the new Kit, which disappeared after I increased the VCore to 1.435V.
    Uploaded with ImageShack.us
    I did a tiny upgrade:
    - 2x Gigabyte GTX680-SOC-2gb ==> 2x Gigabyte GTX780-Ti-GHz-Edition-3GB
    - Antec HCG-900 ==> Corsair AX1200i
    - additional SSD dedicated to run my main games ==> Samsung 840 EVO SATA3 500GB
    Max. Overclock atm.:
    SSD's:
    CPU-Z:
    3770k @4700MHz
    GPU-Z:
    GPU-Clock @1120MHz | Memory-Clock @1823MHz
    Here are my new scores:
    Unigine Heaven 4.0:
    3D-Mark-Score:
    Firestrike (standard):
    17913
    Fire Strike (extreme):
    8956
    Star-Swarm-Scores (Extreme):
    - Follow:
    Code:
    == Results ================================================
    Test Duration:			360 Seconds
    Total Frames:			28124
    Average FPS:			78.11
    Average Unit Count:		4727
    Maximum Unit Count:		5794
    Average Batches/MS:		1403.79
    Maximum Batches/MS:		5365.89
    Average Batch Count:		18597
    Maximum Batch Count:		112724
    - Attract:
    Code:
    Total Frames:			17817
    Average FPS:			49.49
    Average Unit Count:		4419
    Maximum Unit Count:		5484
    Average Batches/MS:		1535.84
    Maximum Batches/MS:		5064.43
    Average Batch Count:		31969
    Maximum Batch Count:		186205
    - RTS:
    Code:
    Total Frames:			9584
    Average FPS:			26.62
    Average Unit Count:		4171
    Maximum Unit Count:		5389
    Average Batches/MS:		2438.91
    Maximum Batches/MS:		6210.71
    Average Batch Count:		87260
    Maximum Batch Count:		172706
    - Shmup:
    Code:
    Total Frames:			24079
    Average FPS:			66.88
    Average Unit Count:		4240
    Maximum Unit Count:		5265
    Average Batches/MS:		1421.90
    Maximum Batches/MS:		5231.63
    Average Batch Count:		20201
    Maximum Batch Count:		109801
    Edit-2:
    New Benchmark-Scores with the latest GeForce v340.52 Beta:
    3D-Mark-Score:
    18240
    10185
    Edit:
    Pushed them a bit further:
    GeForce v344.11:
    18.324
    Edit:
    ... for latest Version goto: Click
    STEAM-ID: TOG | TONSCHUH || ORIGIN-ID: TOG-TONSCHUH
    Everything looks great. What do you use the computer for? It is very high power. Impressive!
      Thanks !
      That's mainly my little Gaming-Rig.
      I like to play FPS, like Battlefield-4 and ARMA-3 at the moment.
        The CPU and GPU's are OC'ed like before, but I use now the GeForce v331.65 WHQL-Driver's and changed my RAM-Timings from 10-12-12-31-2T to 10-11-11-28-2T (DRAM-Voltage: 1.69000 V | VCCSA-Voltage: 1.27500 V):
        3D-Mark-11-Scores
        3D-Mark-Scores
        WEI:
        SystemScore 8.1
        MemoryScore 8.5
        CpuScore 8.5
        CPUSubAggScore 8.4
        VideoEncodeScore 8.6
        GraphicsScore 8.3
        Dx9SubScore 8.3
        Dx10SubScore 0
        GamingScore 8.3
        DiskScore 8.1
        1T seems to be a no go, as I'm only able to reach the Desktop, but then I get like a half-crash, where I can still use the Mouse-Pointer, but Windows doesn't load all Start-up-Apps and is not usuable, as you can't open a Start-Menu etc.
        I had to increase the voltages to prevent BSOD's etc. I will try again 10-10-11-28-2T @2400MHz, which didn't work with only DRAM-Voltage: 1.67500 V | VCCSA-Voltage: 1.27500 V.
          I'm liking what I see.
          Great way to get the most out of your system, my friend!
            Thanks a lot !
            I think that I reached the maximum possible performance for the rig, without spending another arm and leg on it.
            As my GPU's perform at least on the same level as a rig with R290X CF OC, I will wait for the 800-Series from NVIDIA and will possible build a complete new rig next year and hand down this one to my wife.
            She has at the moment my old rig which I partly upgraded (2600k @4500MHz (easily 4900MHz possible, but not needed | max OC was @5012MHz with the AirCon running and very close to the max possible temp's) + GTX570-OC + 16GB (4x4GB) G.Skill @2133MHz).
            As she only play's games from time to time and only games like Diablo-III / Torchlight-2.
              Edit:
              I was able to push the GPU's even further (Power-Target: 106% | Core-Voltage: 1.187V | GPU-Clock: 1241.5MHz | Memory-Clock: 7290MHz), but only re-benched with 3D-Mark:
              Edit-2:
              3D-Mark-Score:
              18240
              10191
              Edit-3:
              Pushed them a bit further (Voltage = 1.187V | Power Target = 106% | Temp Target = 95C | GPU Clock : Base = 1120 / Boost = 1185MHz / Average = 1241MHz | Memory Clock = 7380MHz)
              GeForce v344.11:
              18.270
              Edit-4:
              18324
                My Rig is again under construction and will be soon like this:
                Code:
                My Rig:
                OS: Windows-8.1-RTM-Pro-WMC-Update-1-x64
                CPU: Intel Core i7 3770k @4700MHz @1.435V
                Memory: G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX (10-11-11-28-2T) @1.690V
                Graphics Card: 2x Gigabyte GTX780-Ti-GHz-Edition-3GB in 2-Way-SLI (skyn3t BIOS-MOD | Power-Target: 116% | Temp-Target: 94C | Core-Voltage: 1.212V | Boost disabled | GPU-Clock: 1255MHz | Memory-Clock: 7380MHz)
                Mouse-Pad: Roccat Alumic Double Sided Hardpad
                Cooling: EK-H3O-HFX-240mm Liquid Cooling Kit | EK-TIM Indigo XS | GELID GC-EXTREME | 2x EK-FC780 GTX WF3 Nickel Acetal | EK-FC Terminal DUAL Parallel 3-Slot Black Acetal | 2x EK-FC780 GTX WF3 Backplate - Black | PrimoChill PrimoFlex Advanced LRT Tubing 3/8"ID x 1/2" OD Brilliant UV Blue | PrimoChill Anti-Kink Coils - 1/2 OD" Tubing - Glossy Blue | 2x EK Ultimate Performance CoolStream 480 XTX Series Liquid Cooling Radiator | 12x BGears B-Blaster 120mm x 25mm 2000RPM High Speed Fan | EK Ekoolant EVO Concentrate - Clear | EK & Bitspower Compression-Fittings G1/4
                PS: ... the upcoming changes are bold ...
                      Some better Pic's:
                          Just ordered a Roccat Pure Military Camo Charge and Roccat Taito Mid-Size 5mm.
                            Core: 1444MHz | Mem: 7000MHz:
                            Core: 1431MHz | Mem: 7354MHz:
                            Core: 1431MHz | Mem: 7328MHz:
                              Asus STRIX GeForce GTX 980 Ti DirectCU III GAMING STRIX-GTX980TI-DC3OC-6GD5
                              There is another small upgrade on it's way, but I'm still waiting for my EK-Blocks + EK-Backplates.
                              They are even @Stock and on Air not bad:
                              I benched this morning again and here are the results:
                              Log-File-Download: Click
                              I used HWINFO64 v5.03-2600 (Beta) to create the Log-Files.
                              DXDIAG: Click
                              I used GPU-Tweak v1.0.2.4 in OC-Mode + Game-Booster activated and didn't adjust the Factory-Settings of the GPU's.
                              Firestrike = 20963 ==> Log: 4600MHz
                              Firestrike = 21811 ==> Log: 4700MHz
                              3D-Mark-11-Extreme = X14647 ==> Log: 4700MHz+
                              ==> Log: 4700MHz++
                              ==> Log: 4700MHz+++
