'Another' Compatibility Query
  • 'Another' Compatibility Query
    Good Day,
    I have a system with an Asus P8H67 M LX motherboard. I want to increase the amount of memory from 8 to 16gb. As space is an issue I am looking to replace the existing memory with something very similar if not the same. Currently installed, G.Skill Ripjaws, 240 pin DDR5 1333 (PC31066), CAS Latency 7. (that's all the numbers I can see). There are 2 memory slots.
    I came across these modules (they look the same) a while ago but before I purchase them I'm hoping someone a lot more knowledgeable than me can advise whether they would be compatible with my system.
    G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Intel Z87/ Z77/ Z68/ P67 Low Profile Extreme Performance Memory Model F3-1600C9D-16GAB
    • DDR3 1600 (PC3 12800)
    • Timing 9-9-9-24 2N
    • CAS Latency 9
    • Voltage 1.50V
    If there is any other pertinent info I need to add please let me know.
    Thanks in advance for any help someone may be able to offer.
    Any other model recommended would also be appreciated.
    Cheers.
    Fred
    Those should work great for the motherboard
