When using 2 ram modules in both dual channel or single channel the games are crashed, but if I only use a ram memory nothing happens and I can play without problem. My motherboard is a Gigabyte B450 DS3H V1.0 and the ram 2x8gb G. Skill RipJawsV 3000mhz, Amd Ryzen 3 3200g with radeon vega 8 graphics
Ram problem
Ram problem
When using 2 ram modules in both dual channel or single channel the games are crashed, but if I only use a ram memory nothing happens and I can play without problem. My motherboard is a Gigabyte B450 DS3H V1.0 and the ram 2x8gb G. Skill RipJawsV 3000mhz, Amd Ryzen 3 3200g with radeon vega 8 graphicsTags: None
Originally posted by GSKILL TECH View PostCan memory in first and second slot away from CPU work properly? Or 3 and 4? Do you have the latest BIOS?
I already tested them in 1-3, 2-4, 1-2 and 2-3 and the problem persists, change the latencies for compatible ones for that board and the problem still follows. I have the latest Bios update which is F50 in gigabyte b450 ds3h v1.0
Try one of these for guaranteed results:
https://www.gskill.com/configurator?...6GB%20(8GBx2),
Or you can send the memory kit in for RMA exchange to see if a replacement can work better.
